Disabling the brake pad light sensor light
Rushfan1
Post by Rushfan1 »
I have no use for the sensor, do I just ground the wire near the brake pad or is there another way to disable the brake pad light sensor light on my dash?
murran
Re: Disabling the brake pad light sensor light
Post by murran »
remove dash pod/insturment display.... and take the bulb out?
drjim
Post by drjim »
Easier - work out which of the wires need connecting together at the sensor end and connect them together. As I recall there are three wires in there. removing dash is far too much work!
1982 Saphirblau Baur 325i
Cars all gone!
cdavie2002
Post by cdavie2002 »
Thats the way i did it. You need to find out which 2 of the 3 wires need connected to turn warning light off.
Chris
1982 320/6 (breaker)
1975 3.0 csi
1974 3.0 csi (donor)
2003 E46
