ABS problem
rotaxmaxke
ABS problem
Post by rotaxmaxke »
I have a problem with the ABS system. :(
The orange ABS light stays on when I start the engine.
The light was disconnected, so I think the previous owner know there was a problem. :evil:
What can I check ?
All the fuses are good.
a proud 320is owner
You can check the ABS cables for tear and wear, the rear sensors usually are a PITA to remove but you can remove & check the front ones on dirt buildup. Next up is a check on the ABS cable connectors (yellow-orange round connectors, two on the front wings and two under the rear seat)... there might be some corrosion. Last easy step is to replace the ABS computer that's located underneath the dash at the drivers' side.. borrow one from another E30 (any E30 with ABS will do) for a test.
rotaxmaxke
I will check it
Thanks for your reply :wink:
a proud 320is owner
rotaxmaxke
yeahoow I found it :lol:
a stupid little fuse-wire inside the main-relais was broken
here you can see the inside of the relais
I fixt it and it works again
Found it beacause I bought a electrical manual :wink: [/img]
a proud 320is owner
OK good news and thanks for the update. Next time we know another place to search!
