info e21 m50b25 rear subframe
e21bart
Post by e21bart »
hi guys,
To get any help i've read a lot on the internet about the 'famous' engine swap with an m50b25. but i've heard something about putting an e34 5 series rear subframe under an e21 type 2. Does anyone know more about this? I would appreciate some help ;)
thanks in advance
bart
Jason_323i
Re: info e21 m50b25 rear subframe
Post by Jason_323i »
Never heard of that, what you do need is an e34 m50 sump to fit the m50 engine into the e21 shell
Z3M Coupe
2.8 Z3 Coupe
Caterham Supersport
e21bart
Post by e21bart »
Well im going to put in the m50b25 gearbox to so i will have to make a diff fit on the rear sub of the e21. My boss told me he did it that way but he wasnt sure. Imma put photos online when i figured out how to solve this problems
Thanks!
id be very interested in seeing how you get it to fit, dont think anyone on here has done that before!
Thijsse
Post by Thijsse »
why not make a 9 point star on your driveshaft with a sensor on it?
you also need to fit a e30 speedometer in your dash, and connect the right wire to the m50 ecu, otherwise it won't run like it should
Jason_323i
I think the black m60 V8 e21 had an e34 diff.
Jason
Z3M Coupe
2.8 Z3 Coupe
Caterham Supersport
e21bart
Post by e21bart »
Nice! Can u give me a link i cant find it :(
Thx
