holed sump (speedbump)
jimbob
Post by jimbob »
hi all had a fight with a speed bump and lost ,got a replacement sump
but i cant fit it til next week. can i get away with liquid metal for a bit
E36 328i Daily driver
E36 328i Touring
murran
Re: holed sump (speedbump)
Post by murran »
depends how bad really. having said that ive seen someone with a big hole repair it with a coke can and liquid metal. its good stuff.
surfaces need to be clean of oil so if its dripping out of the crack you need to drop it out of the sump first. clean it up and sand down the effected aera. mix the liquid metal and slap it on. let it cure and refill with oil. if its no longer leaking dont bust your balls about rushing to find a new sump.
jimbob
Post by jimbob »
it isnt a major crack just a small hole where the sump plugs been bent previously
just enough for a constant dripping.ill have ago tomorrow
thanx
E36 328i Touring
cobbler2u
My E21(s): 323i baur
323i special
328 sport
325i
Post by cobbler2u »
Just had to do the same tonight.
So far so good no oil drips. Will let yo now tomorrow as i did it as it was still dripping small amounts.
jimbob
Post by jimbob »
chemical metal is working a treat no drips or leaks :boogie
when i do change my sump will it come straight off or do i
need to raise the engine? it looks tight over the subframe
E36 328i Touring
Reck
Post by Reck »
I think you might need to unbolt the engine mounts and lift it slightly, or remove the subframe. :\
[edit] Make sure you have a proper sump gasket to hand aswell! - Liquid gasket wouldn't cure on the sump we tried!
jimbob
Post by jimbob »
ah thought it looked tight.think i will wait til i can get it on a lift then
E36 328i Touring
murran
Post by murran »
you do need to lift the engine up.
in an ideal world.....
buy one of these.....
http://www.ebay.co.uk/itm/DRAPER-ENGINE ... 2a1440195b
you can easily sell it again when youve used it for what you pay for it....
jack it up and stick it on two stands, unbolt the engine mounts... put your new support beam across the inner wings. wind the thread down on it and put it round the front lifting eye on the engine. lift engine up by winding up the thread till you have enough room to get the sump off. you only need to lift it 2-3 inches to get the sump off.
without the support beam your left jacking the engine up under the sump and trying to wedge it up with blocks of wood under the mounts and its not very safe.
unless you know someone with an engine crane to lift it up abit, but then youve got the front bars of the crane with the wheels on under the car where you need to work to get the sump off.
jimbob
Post by jimbob »
thanks murran the garage i use has one of those i can borrow (i didnt know what it was til you explained)
will make it much easier when the time comes
E36 328i Touring
murran
Post by murran »
normally the're used on fwd cars to support the engine when your changing the clutch/taking the box out.
if you have access to borrow one then thats cool!
