Question for all E21 owners
ivo316
Post by ivo316 »
Hello everybody:
I own an E30, but it came with an M10 engine and a pierburg carburator, I wanted to ask you (if you have one of those), to take a picture of your setup and post it, because my car was serviced by the previous owner's mechanic and he removed all the hoses (even the vacuum advance), so you can imagine how the car runs, it idles like a diesel and accelerates even less.
As I can see, the main difference is the electric (or electronic) plug beside the carburator which runs the economy meter.
I also have a 2 barrel solex, which seems a lot simpler, but has 2 electric sensors, would you advise replacing the pierburg with this solex ?
I am sorry to barge in here, but I have been to E30 forums, but therfe are very few M10 carburated engines there.
thanks in advance
Ivo
Re: Question for all E21 owners
They're both pretty useless tbh. If I were you, I would fit a Weber instead. Better running, better performance and, so long as you don't boot it everywhere, better mileage.
Reck
Post by Reck »
Myself and Wizor are both selling Webers;
http://bmwe21.net/forum/viewtopic.php?f=6&t=16067
ivo316
Post by ivo316 »
OK, thanks for the advice, BTW, I might as well buy it locally, Since I'm in Chile, shipping costs would be psychotic.
I'll keep you updtaed on what happens.
ivo316
Post by ivo316 »
Hey, BTW, there are severa sizes avalable, 30/30 32/32 40/40, which do you advice for the 1.8 stock M10 ?
thanks in advance
Ivo
murran
Post by murran »
is it a 2e2 pierberg like a mk2 polo/golf? i have a pulldown unit and a wax stat somewhere.....
ivo316
Post by ivo316 »
It's a pierburg which has two float bowls, one at each side of the carb, I couldn't find an image of it on the web, and it has an electric plug behind (towards the firewall), this plug receives one vacuum hose (if disconnected the car will not run).
I may be able to upload a pic tomorrow. (I have to take a pic of the actual carb).
