Specs
2.7 S eta stroker 129hp
completely modified 885 325i cilinder head with al new parts
rockers enlightened
block and head skimmed comp ratio now 9.6/1 was 8.5/1
crankshaft, conrods and flywheel balanced an weight out
pistons machined (valve seats)
dbilas 282/272 camshaft and springs
bigger injectors m50
bigger air flow meter (m30)
wiring loom from 325i facelift
ecu modified alpina b3 2.7 setup
The pics then:
