bulge on my bonnet
- petroscf
bulge on my bonnet
I found a small bulge on my bonnet, exactly at the area over the highest point of the strut bar (which is exactly under there)
Ok, this means GREEK ROADS !!!! (and lowered E21, of course)
However, could this be also meaning it's time to replace my bilsteins?
/oo=00=oo\
E21 Forever
E21 Forever
- e21-Mark
- E21 Master
Re: bulge on my bonnet
Your strut brace hitting the bonnet shouldn't have anything to do with your suspension.
Your inner fender and strut top should not be moving relative to the bonnet otherwise your car will be falling apart in a matter of days. Strut bar may be on the high side, have seen that before.
- petroscf
Meaning I have to look into this ASAP ????
/oo=00=oo\
E21 Forever
E21 Forever
- e21-Mark
- E21 Master
Have you checked everything is bolted down as it should be?
- petroscf
Well, I was thinking that yes, up to now.
I will take the car to a body service (??is that the right term??)
who is a good friend as well, to have a look at it...
/oo=00=oo\
E21 Forever
E21 Forever
- e21-Mark
- E21 Master
Open the bonnet and check the 3 nuts that hold the brace to the top of the front struts. If they are tight, the brace cannot move and hit the bonnet. If they're loose you need to tighten them as your front suspension will move about all over the place.
I guess it's still just the brace being too high as happend more often, and that you just woke up to find out it had been rubbing the bonnet for ages already.
- petroscf
well, actually it is not "for ages" as the bar was fit this summer...
But, yes, I should and will have the car checked...
/oo=00=oo\
E21 Forever
E21 Forever
