Z3 or E36 steering rack?
JTY
My E21(s): 1981 323i
Post by JTY »
Am I right that a Z3 or e36 steering rack is a popular swap for e30s (shorter)? Anyone any experience with fitting these to an e21?
Re: Z3 or E36 steering rack?
Not much I guess, was discussed before, since the steering rack is on the other side of the front crossmember it's not exactly a straight fit (like it is in an E30 indeed). Jason sells quick manual E21 racks if that's what you're after.
petroscf
My E21(s): '77 EU 316 manual
Post by petroscf »
Does Jason sell for LHD as well??
/oo=00=oo\
E21 Forever
JTY
Post by JTY »
No, Jason only sells RHD that I know of.
nightbear
Post by nightbear »
and that's exactly what you would need. we have a lot of RHD e36 steering rack swapped e21s over here, if you want to I can get you some info with pics later on..
rob0r
Post by rob0r »
nightbear wrote:and that's exactly what you would need. we have a lot of RHD e36 steering rack swapped e21s over here, if you want to I can get you some info with pics later on..
Please do, that's very interesting. Where is "over here"?
JTY
Post by JTY »
Yep, still very much interested too. But bare in mind that I would be needing a short rack for a LHD 323i...
Jason_323i
Post by Jason_323i »
Well I sold I few e21 racks to m3 owners to flip over an fit to LHD i am sure the reverse works. As the e21 and e36 racks are on the other side of the cross member from each other flipping over a lhd rack makes it work for LHD and visa versa.
What I need is a LHD e46 compact rack cheaper and just as quick as the z3 1.8
Z3M Coupe
2.8 Z3 Coupe
Caterham Supersport
JTY
Post by JTY »
Not sure I understand everything with the e36 and e46 in your message, Jason.
If I want a quicker rack on my LHD e21, I look for a RHD e46 (should that be e36?) compact rack and flip it over to go on the e21? Is that right?
JTY
Post by JTY »
Jason or someone else, is it e36 or e46 (see message above)?
Cheers
Jeroen T.
Jason_323i
That is the basic theory a flipped over e36 z3 1.8 or e46 compact rack (the quickest ones) of course in practice you need to modify steering linkages make mounts on the subframe and new power steering lines
Z3M Coupe
2.8 Z3 Coupe
Caterham Supersport
I've got a non-PAS e36 rack in my e30 track car. It's a good conversion but a some people simply seem to find the steering too heavy, compared with what they're used to. I think it's fine although obviously a bit heavier for parking if you'll be using on the road.
kevralpina
Post by kevralpina »
TAS in the uk used to do a quick rack kit for the e21 in lhd and rhd got one fitted to my own car slightly heavier as to be expected but the response so much better
chelby5
Post by chelby5 »
Here in Ukraine wheel on the left side and I put a rail on the right-hand drive E36, just flipped.
JTY
Post by JTY »
Interesting! Could you do a round up of all mods needed or maybe a 'howto' with each pic?
