Broken gearbox mounting point
cdavie2002
Post by cdavie2002 »
Bought a manual gearbox but unfortunately its chipped at one of the mounting points. Just by looking at this diagram, can anyone tell me if this is a simple mounting point or does the starter also bolt on here?
Any ideas as to how/if this csan be fixed?
Chris
1982 320/6 (breaker)
1975 3.0 csi
1974 3.0 csi (donor)
2003 E46
Re: Broken gearbox mounting point
Doesn't really do owt that bolt. you'll be fine but id repair that missing bit.
Starter goes onto the bulge on top so for fitting you'll be fine
cdavie2002
nas80 wrote:Doesn't really do owt that bolt. you'll be fine but id repair that missing bit.
The missing bit is the bolt hole.
Chris
1975 3.0 csi
2003 E46
Duracel79
Post by Duracel79 »
I thought there was a dust cover plate that bolts up to that hole and the other two small lower holes.
Not really needed but I'm guessing two bolts will be enough to retain the plate.
Ben
EDIT:
See the plate etc here:
http://www.realoem.com/bmw/showparts.do ... g=23&fg=10
