no brake fluid
jimbob
no brake fluid
Post by jimbob »
went to do some bits on my 323 today and my brake fluid is down to the bottom of the
resevoir.ive checked all the pipes and every caliper and got someone to pump the pedal but i cannot find
a leak anywhere? anyone got any ideas
E36 328i Daily driver
E36 328i Touring
Re: no brake fluid
Tank leaking due to a bad connection to the brake master? Otherwise, and this is most likely, the master is leaking into the brake booster showing no leaks anywhere... new master or overhaul required.
jimbob
Re: no brake fluid
Post by jimbob »
thanks jeroen ill get it looked at the tank is fine and the connections are good so this must be it
E36 328i Touring
DrGonzoPOW
Re: no brake fluid
Post by DrGonzoPOW »
Check that the slave cylinder is not leaking, it usually drips down from the gear box bell housing if thats shot.
Also check under the front carpets. My master cylinder was leaking down into the drivers footwell and i knew nothing about it as it went underneath the soundproofing and carpet.
Wakefield Hellfire
Re: no brake fluid
the pick up for the clutch is abt halfway the tank to prevent you from running out of brakes because of a leaking clutch system. So if the tank is really empty it can't be (just) the clutch.
jimbob
Re: no brake fluid
Post by jimbob »
mines an auto too so i think the master leaking into the booster sounds most likely
E36 328i Touring
jimbob
Re: no brake fluid
Post by jimbob »
im going to take the master off in a couple of days and see whats wrong.
what do i do about the fluid thats leaked into the booster?
can i just empty it out if so is it just a case of taking it off the car and tipping it out?
will the booster be ok or will it be damaged?
E36 328i Touring
Saphire
My E21(s): '76 316
Re: no brake fluid
Post by Saphire »
check brake pressure regulator, in my case i have leaking there.
Re: no brake fluid
I had the same problem and indeed it leaked into the booster. I emptied it en cleaned the inside with washing petrol to make sure it would not get rusted.
jimbob
Re: no brake fluid
Post by jimbob »
mine was a leaking master cylinder.got a service kit from big red for £19 now all is good
E36 328i Touring
