radiator extra holes on the bottom
GerritBuggenhout
My E21(s): '82 320/6 manual
Post by GerritBuggenhout »
there are 2 extra holes on the radiator with thread but i don't know what they are for.
what are these holes for?Image
Re: radiator extra holes on the bottom
That's a radiator for the automatic version, the bottom part is the gearbox oil cooler (ATF), ATF lines connect right up to those points.
Something tells me you do not have an automatic :?
yeah the transmission is cooled in the bit at the bottom - just fit a tube between the outlets if you cant find the right size bolts.
GerritBuggenhout
goddamit!! i realy looked at it and they sent me the wrong one !!
Last edited by GerritBuggenhout on Fri Mar 30, 2012 11:32 pm, edited 1 time in total.
Should still work fine though. Just means the bottom section won't be used.
m3gaz
My E21(s): looking
Post by m3gaz »
Its a rare item.
GerritBuggenhout
it's fixed and fixed nice :D
Shiny new radiator :D
