First of all, no wheel on car pics as yet as the spacers haven't turned up yet
I have however been doing a few little bits and bobs.
When I first got the car the exhaust back box was hanging down as there were no exhaust rubbers holding it up. I initially had it held in place with metal cable ties (which did the job) but within a few days I had a knocking from the exhaust. So I thought I would replace the ties with the correct parts
there turned out to be two rubbers missing on the back box and one perished on the centre section. All three were replaced.
I began to get a squealing from the auxiliary belt so after going and buying one I found out that I could just tighten the existing one by adjusting where the alternator sits. So now I have a spare belt and no more squealing
When I bought the car I got given a spare unripped passenger seat as the existing one has started to rip on the cording. So 5 minutes later the new seat was in and looking a lot better (sorry no pics
While I was having a little play under the bonnet I decided to sort out the ludicrous idle, when cold it would idle at roughly 1000 rpm and when warm about 1200 rpm. So I got my screwdriver out and adjusted the idle screw (got to love old skool mechanics) and now she idles perfectly at 5-600 when cold and 800 when warm
When buying the car I got told the sunroof didn't work and got given a new sunroof mechanism to replace the existing one, I thought I would see how bad the sunroof mechanism was (a decision I regretted for about an hour
) I tried to open the sunroof, which opened pretty well, the damn thing refused to shut! So after wrestling with it and swearing for an hour I finally got it to shut.
I have had a quick look and it seems the roof lining needs to be taken off in order the fit the new mechanism. I decided that enough was enough and left it for another day.
Sorry about the lack of pictures, I intended to take more but got sucked into tinkering and forgot about it.
