ok so planning on doing an engine conversion on my 1980 316 e21
is the chassiss etc able to handle 180-200bhp?
brakes etc will be upgraded also just afraid of trailing arms ripping the floor out as is common in e46s
What power can it handle
Irish_chris
- My E21(s): 81 318, 83 316t
Re: What power can it handle
Shouldn't be an issue, many guys here installed M50 engines or worse and there were never problems with the 200-218 BHP Alpina versions either. The occasional driveshaft gives up but I expect worn universal joints are most likely to be the cause. A set of urethane all round may be advisable though!
What he said.
If I was you id stick a strut brace on . It really does make a difference.
Agreed - best chassis / suspension mod you can do to an e21.
Irish_chris
funny you should day that, i was intending to fit a strut brace, can anyone point me in the direction of a good value but decent one?
drive shafts shouldnt be a problem ive a feww spare here
thanks lads
thanks lads
- PeteK
- My E21(s): 1979 323i Euro
More stopping power should always come before more going power!
Pete K
'79 323i (for good times)
'81 M535i (for collecting)
'75 520i (track machine)
'03 320i (for commuting)
'97 Laser
'97 Laser
Irish_chris
completely agreePeteK wrote:More stopping power should always come before more going power!
ill be fitting wilwoods at the same time
