Wiring connector identification help required
problemchild75
Post by problemchild75 »
The two plugs below are from a 316 interior loom and I want to know where they go without pulling my interior to bits at mo. where do they connect to please?
mr edd
Re: Wiring connector identification help required
Post by mr edd »
the one on the right in the picture go's in the right side of the instruments/clocks (temp side gauge side )and the other on the left looks like it is for the ignition switch which connects just under the dash to the right hand side of the sterring column(there is a bracket on the dash support/crossmember for the plug to clip onto)...
e21 316 (1981) TRE702X.
problemchild75
Thank you :thumbsup
