Clutch type radiator fan.
pampa
- Newbee
- My E21(s): 1982 E21 323i 5spd .1967 Triumph TR4a
I am trying to remove the clutch type fan from my 82 323i. Is the thread left or Right hand and is there any special knack to removal?
Re: Clutch type radiator fan.
Based on year I'd say you have the late style with the 32mm nut with reverse thread. I used the search function which got me this recent discussion on removing the fan. Will try to add a similar item with pics to the FAQ section soon.
http://www.bmwe21.net/forum/viewtopic.php?f=3&t=19402
i was wondering if matey actually got that nut off using the swift wack with a chisel method (if my name was steve jobs id have patented it)
the thread is OPPOSITE to normal - as in you turn the nut clockwise to take it off.
pampa
- Newbee
Got the fan off with a fair bit of effort,it won't be going back on. Thanks for the help.
