..just wondered if there were any Solex 4A1 geniuses on here
My newly painted E12 has a mysterious fault which I've not been able to get to the bottom of.
The car runs fine, virtually all the time. The problem occurs on long motorway journeys of about 140 miles. I take a break half way through the journey about 80 miles in, the problem starts without fail about 130 miles into the journey. Suddenly the accelerator stops responding and the car slows down to about 40mph (not ideal on a motorway
), you can just about keep momentum going with the accelerator floored but the power only comes intermittently. It eventually seems to recover, although I usually turn off onto a B road... Any ideas on this would be gratefully appreciated.. We've tried all the likely solutions, like new fuel filter, fuel pump is recent.. Carb icing was one idea... The way it happens at virtually the same time on each journies is puzzling though
Keen to make the sharknose meeting this year, this fault is kind of holding things back though
