I took my car up on a lift and changed the coolant, and when I should drive it off, it wouldn't start... I suspect it's the fuel pump, since I can't hear it "buzzing" when I turn on the ignition, but I'm not sure.
There's no spark, but that's because there's no fuel I think...
Anyone experienced this before???
Car won't start.... Edit; Fixed :-))
- Orjan
- My E21(s): 1979 BMW 323i
Re: Car won't start....
Orjan,
The spark and the fuel is not connected. No fuel does not mean you will not have a spark.
No spark and no fuelpump must be something electric.
Looking the ground cable connect on the subframe first. If it's ok, take a look to the fuel pump fuse!
- Orjan
It was the "thermal switch"; I unplugged it and the engine started like a charm
http://blog.bavauto.com/9667/bmw-e21-32 ... when-warm/
- Dan323i
Re: Car won't start.... Edit; Fixed :-))
Mine can be a bit reluctant to start once warm (and sat for a bit) so I'll give that a try next time, thanks!
I am working on a E21 323i with the same issue. We will try it next time. Thanks.Orjan wrote:It was the "thermal switch"; I unplugged it and the engine started like a charm![]()
