Wheel advice please
S17ewo
My E21(s): 323i
Wheel advice please
Post by S17ewo »
Hi all, apologies for the vagueness of my questions but I'm currently in Afghanistan and haven't seen my new e21 in the flesh yet. I believe the wheels are standard 15" bbs alloys, do you all think this is the case, and also if it is, what is there et? Basically I'm looking at a set of bbs rm's, they are 7.5j fronts et 22 and 8j rears et 14. I wanted to know how these would sit in comparison to the standard wheels? Any help is really appreciated as I can't help myself but want to get started on making her my own. Anyways enough talking, here's a pic......
Re: Wheel advice please
Standard E21 offset is ET13, which goes some way to explaining the limited number of suitable rims available.
You'll need a 10mm spacer up front, to clear the TCA. The rears should be fine. You'll need to run some stretch and ideally, have your arches rolled, to get some extra clearance. This is dependent on the ride height obviously. I ran 8's & 9's on my old car.
Theres a website called www.willtheyfit.com
You need a spacer at the front if you have a rim thats less that et13 because it will touch the track rod end. This isnt a problem if you run 16's as theres enough room.
TopCat
My E21(s): 1980 Alpina B6 2.8
Post by TopCat »
those wheels look a bit like E30 BBss?
wonder if your number plate would be worth something to an IT expert URL anyone?
Regards
Topcat
Isle of Man Inverness
1980 BMW E21 Alpina B6 2.8
1991 BMW E30 Hartge H26
S17ewo
My E21(s): 323i
Post by S17ewo »
Thanks for the help guys, is it good or bad if there e30 bbs's?? Haha I suppose it could be, know of any IT experts? Haha
S17ewo
My E21(s): 323i
Post by S17ewo »
Also lads.....what's the centre bore of an e21....there 4x100 correct??
Same as a vw mate. 4x100 57.1
S17ewo
My E21(s): 323i
Post by S17ewo »
That's pretty sweet!!!!! Gives plenty of options!!!
TopCat
Post by TopCat »
Nas love your new Avatar
Have felt just like Basil several times this year when
1 halfshaft broke and dropped wheel on CJ Jeep in snowdrift in lane outside house
2 Herman's ECU packs in last run on Sloc Hillclimb
3 Even my MG ZT-T (last car working) developed a massive fuel leak
4 GMC Camper had a similar fuel leak
5 Camilla's heater matrix started to leak
URG- Old cars.......................
All now fixed!
Regards
Topcat
Keeps you busy haha!
S17ewo
My E21(s): 323i
Post by S17ewo »
Sorry to bother you again lads, as one of the rear 2" dishes is slightly kinked I've been looking for other dishes kicking around, found some 3" rears and 2" fronts, how much room is there for these, I want to run fairly low ideally but want as much dish as possible at the same time....
Ive had 3" dish on the back but had to run skinny tyres and massive camber. It was cool to look at but with all the power it was wasted.
S17ewo
My E21(s): 323i
Post by S17ewo »
Thanks for the heads up bud, will steer clear as like I say I want to drop it a fair bit.....did you get my pm about the headlight grills?
S17ewo
My E21(s): 323i
Post by S17ewo »
Sorry to resurrect this lads but basically these are the wheels I've finally picked up for the e21
http://classifieds.wheel-whores.com/cla ... s/view/169
Firstly can anyone tell me there offset running the current dishes....and also do I just need a 10 mm spacer up front? Can I use the standard BMW wheel bolts? And finally I'm picking up 4 205/45/15s so if anyone has 2 195s they want to swap for my fronts that would be a sweet extra bit of stretch ;-)
20mm spacer
