I'm having some trouble identifying the partnrs of the vacuum hoses for my '81 323i. I don't recognize all of them on http://bmwfans.info/parts/catalog/E21/S ... se/engine/. Anyone already ordered all of them new? Which partnrs did you use?
Many thanks
Jeroen T.
Quickie: Partnrs vacuum hoses 323i *now with pic*
- JTY
- My E21(s): 1981 323i
Re: Quickie: Partnrs vacuum hoses 323i
Perhaps you can be more specific as to which hoses are unclear to you (bmwfans.info pics) together with some pics of your engine setup so we can fill in the gaps? And some more info, car probably does not have an EGR system? Do you have an electrical aux air slide valve or the one operted by coolant temperature? In many cases build date doesn't say it all even though a parts search based in vehicle VIN may rule out a bunch of options.
- JTY
Problem is I can't find my pics anymore with detailed views of the hoses after I removed the engine... #myfault. It's aJuly '81 Belgian car. Because I want to make sure all of the vacuum hoses are fine, I want to replace them all.
- JTY
If found a pic! It are about all the hoses you see here:
