Indicators, wipers fail
CrazyNick
My E21(s): 82 320/6 E
Post by CrazyNick »
Hi. New here
At the weekend I bought an 82 320/6 limited edition. I'm not really used to BMW engine codes but am I right in saying this has the M20 engine?
Anyway on my 1 1/2 hr journey home from buying it the indicators and the wipers decided to stop working. And guess what it started to rain too. Quite scary at night, had to drive with my head out of the window so I could see where I was going.
The hazard lights still work.
So I'm guessing that there is a loose wire or contact somewhere behind the steering wheel. I can't figure out how to remove it?
Re: Indicators, wipers fail
Moving to the tech section. Please note that these are all on fuse Nr 15 (also see http://www.bmwe21.net/?page_id=130 ). Try rolling the fuse, the contact may be oxidated or the fuse blown.
BTW welcome here! Feel free to present yourself and your car in the 6 cil section of the Owner's Gallery... engine type is M20 indeed.
CrazyNick
Post by CrazyNick »
Thanks, all the fuses looked fine but I will try cleaning up the contacts.
I will get some pictures up sometime
General Lee
Post by General Lee »
Hello Nick, welcome!
I ran into the same problems last weekend :-( .
Do your hazard lights still work?
Hazards that are claimed to be still working made me guess for the fuse as the hazards are on a different fuse (17).
General Lee
Didn't read that far apparently :-) , sorry
I have the same problems
CrazyNick
Post by CrazyNick »
Wow your absolutely right. It was just poor contact on one of the fuses.
And I had been routing around under the steering wheel looking for a loose earth wire or something.
Thanks
Reck
Post by Reck »
Get used to spinning the fuses on a fortnightly basis! First thing you should for any electrical gremlin. The next culprit is usually the hazard switch. Then bad earth.
:thumbsup
General Lee
I also changed the fuse but the problem is not completely solved I'm afraid.
Wipers work perfect but indicators only on the left side. When I want to use the right side it makes a noise like one of the bulbs is broken, which is not the case and indicator signal in my dash doesn't work either. The fuse also tends to burn when I want to use the right side.
short circuit in your wiring? indicator stalk can have a loose metal part inside as well causing a short circuit, if the fuse blows that would be my first things to look for...
