Changing different - speedo correction?
- Dan!
- E21 starter
- My E21(s): M42 powered '81 316
- Facebook page: DanielHargravePhotography
Hi there, I have a longer ratio diff off a 320 to use on my 318. Will this require a new speedo sensor? If so where is it located? Thanks in advance, Dan.
- e21-Mark
- E21 Master
Re: Changing different - speedo correction?
No mate, your speedo drive is from the gearbox.
meaning you need a different speedo as the correction is built in there, otherwise it will never know what final drive is fitted. See under top tech topics.
