Auto to manual this weekend
LeeLee
My E21(s): E21 316 1981
Post by LeeLee »
I'm doing a manual conversion on my 316 hope all goes well,one question do I need to use the diff from the manual car? Or can I use my current one
brennon
Re: Auto to manual this weekend
Post by brennon »
Use current one ;)
Just remember the importance of putting the spigot bearing in square. It's a real nightmare if it gets jammed!
LeeLee
Post by LeeLee »
Do you mean square on the shaft or square in the flywheel? Is it a Fiddly one,
Reck
Post by Reck »
Also, double check your prop is the correct length - I've been caught out with that twice now!
brennon
Post by brennon »
Defiantly need manual prop, the difference on mine with the m20 was only around 4cm, close enough to look the same at a glance!
LeeLee
Post by LeeLee »
Im getting the prop from the manual car ;)
Swap succesfully ?
LeeLee
Post by LeeLee »
Yes check out my profile in owners gallery ;)
