Which cars used E21 Rear lights
TopCat
My E21(s): 1980 Alpina B6 2.8
Post by TopCat »
This should get the experts guessing!
I shall start off with....................
The Venturi
http://www.productioncars.com/photo-gal ... Atlantique
Regards
Topcat
Isle of Man Inverness
1980 BMW E21 Alpina B6 2.8
1991 BMW E30 Hartge H26
Re: Which cars used E21 Rear lights
Nice challenge! Saab 900 speedster prototype
e-einundzwanzig
My E21(s): '82 318i manual
Post by e-einundzwanzig »
VW Scirocco II
TopCat
Post by TopCat »
Good calls guys
Jereon- cld you add a venturi photo pse?
Ps did you recognise the hillman hunter rear lights on the aston martin v8 (the one that looks vaguely like a proper camaro?
Keep the e21 examples coming pse!
Regards
Topcat
So many car parts being used for other cars, and most times the more exotic examples to keep the cost down. Here's a Venturi rear that clearly shows the tail lights
polov8
Post by polov8 »
e-einundzwanzig wrote:
VW Scirocco II
I'll grant you they look really similar, but having owned and broken a couple of mk2 Roccs, I can guarantee they're different!
Shame though, that'd have got you to an Aston martin, that uses Scirocco rear lamps!
Andy
Wonder if a Scirocco lamp will fit though?
croma_man
My E21(s): '83 EU 327i
Post by croma_man »
who is going to try? :mrgreen:
another problem that I see is that the lights are not 2 piece, so fitting to a E21 can be a slight problem.
:mrgreen:
I might buy a single light and see if the lens can be separated? Just as a bit of fun / idle curiosity.
Not at this price though! :screwy
http://www.ebay.co.uk/itm/Volkswagen-Sc ... 5d46d62bdc
croma_man
Post by croma_man »
e21-Mark wrote:I might buy a single light and see if the lens can be separated? Just as a bit of fun / idle curiosity.
I think it could come out interesting, as on the aston martin, the gap between the lights is smaller and it makes the car more massive.
Report if you'll do the chop chop part :takepicture
arshad76
Post by arshad76 »
What an awesome thread, I wouldn't have known otherwise!
UK Moderator
TopCat
Post by TopCat »
I took one of these around Silverstone in period- simply the fastest car I have ever driven- had carbon brakes which operate the opposite to a Camaro with old steel brakes- you have to warm them up by braking over a longer distance ( say hanger straight)! Camaro brakes you want to use as little as possible in one last minute shove!
Quite beautifully made - plenty of room with integral rollcage- warning lights work back to front (French eh!) as well
Suddenly saw a yellow light on dash marked "Presion"- crawled around v slowly to pits- yes that is the Oil Light sure enough- but that means oil pressure is OK!!
Their weakness was the gearbox I seem to remember- but 600 bhp and under 1000 kgs made for fun................
Regards
Topcat
Nice! And the design isn't half bad either!
Anyway, any other suggestions? There should be one or two more?!
