M50b20 swap
Mohanad Hani
My E21(s): 315 1979
M50b20 swap
Post by Mohanad Hani »
Hey guys, i was thinking about a swap for my E21. I found that M50b20 is a good choice. What do you think i should do. And did any body made this swap before ?! What i only know that i should take that engine from an e34 because the oil pan is away from the floor so it won't be broken. What else ?!
Re: M50b20 swap
Please use the search function of the forum, this topic has been covered several times already.
Mohanad Hani
My E21(s): 315 1979
Re: M50b20 swap
I did so and did not found anything concerning the oil pan
Re: M50b20 swap
M50b20 is a bad choice it makes less power then the m20b25
Re: M50b20 swap
Agree, better do M50B25 or even better still M50B28/M52B28. You need an E34 oil pan indeed, search on M50 e34 oil pan gives you several useful topics.
Mohanad Hani
My E21(s): 315 1979
Re: M50b20 swap
Is the oil pan of the M50b20 is same as M50b25/28 and M52b20/25/28 ?! Or there is difference ?
Re: M50b20 swap
Yes it is. M52 have different and they won't fit
Mohanad Hani
My E21(s): 315 1979
Re: M50b20 swap
So the oil pan of M50b20 is only 1 and i can't get any other that may fit. I found someone here made an M50 swap and he cutted the oil pan !!! Is that ok ? http://www.bmwe21.net/forum/viewtopic.php?t=21630
Re: M50b20 swap
No.
Any e34 with 24v engine has the correct sump.
The 2.0 engine is too slow. I told you that already you'll be sorry you didn't listen
Get the engine and then YOU decide if you need to cut it.
Mohanad Hani
My E21(s): 315 1979
Re: M50b20 swap
I know that u are right but the 2.0L is the only engine which is available. I also need an engine for daily use and here in Egypt it is crowded so the fuel combustion rate will be too high. I was going for an M42 but i thought that a 6cylinder would be better. Am asking about cutting the oil pan because i think the amount of oil which is required to fill the engine will be less and the oil pump should be cutted also or what ?!
Re: M50b20 swap
You guys don't drive on the right so you won't have to cut the sump because you install engine at correct angle.
The 2.0 fuel consumption is about same as 2.5 but has 50hp less. Shame you don't have the 2.5 there really.
I have cut and rewelded a number of the sumps and I add an extra box section on the side in order to keep the same capacity of oil. You are right you do also have to cut the oil pickup and weld that too. Like I say you don't need to do this as you don't have any brake system on the right hand side of your bay like we do in Rhd country
Mohanad Hani
My E21(s): 315 1979
Re: M50b20 swap
Fantastic.
What if i have an e36 M50b20 oil pan ?!
Re: M50b20 swap
Why do you think everyone here says you need an E34 oil pan?
Mohanad Hani
My E21(s): 315 1979
Re: M50b20 swap
I mean if i didn't find an e34 oil pan !!
What is plane B ?
Am asking because i am trying to set plane B for everythink so while doing the project not to stop for a little tiny proplem.
Re: M50b20 swap
Oh man. Just don't bother the swap if your going to ask stupid questions especially after I told you the answer
