Radio Aerial 320/6
priest 008
Radio Aerial 320/6
Post by priest 008 »
Here is a link to my Radio Aerial, the one on the left is mine and it is located at the front on the left hand side. It recently snapped.
http://www.realoem.com/bmw/showparts.do ... g=65&fg=30
1)Where can I buy one?
2) Is it an automatic thing?
Thanks for your help
Microang
My E21(s): 1981 BMW 320/6 E21 Manual Sunroof
Re: Radio Aerial 320/6
Post by Microang »
Yep that's the standard aerial, as for where you buy it, try the local dealer or Wallothnesch
http://www.wallothnesch.com/antenne-fue ... 01-15.html
Or on eBay, I believe it was NLA from the dealer. Its just a manual version, the auto versions usually go to the rear so there's enough room to fit the entire unit in a dry place (well, usually) in the trunk. May start to look like this then (stolen from member Remy): :wink:
I don't use it too much as I love the M20's music better so I stayed with the original example myself.
priest 008
Thanks! You guys are the best!
priest 008
Ermm, is it difficult to install? How do I access it? Is there a manual with pictures? :P
Just follow the tube lol, believe 2 screws on top and two more at the bottom behind the plastic cover in the wheel arch.
heidjan
My E21(s): '82 316 manual
Post by heidjan »
If you go for the auto version as depicted by Jeroen, you can buy it here http://www.conrad-electronic.co.uk/ce/e ... a?ref=list. I used it to replace mine. With the hole already drilled and the cables already available it was not such a difficult job...
priest 008
Heidjan, If I got the auto version, can I fit it instead of the manual one in the same place?
heidjan
Post by heidjan »
I don't think that will work because a) there's not enough space b) i don't think it's well protected against water and lastly, c) the mounting method of the antenna itself is not suitable for that place. As you can see on realoem at the desriptions, an auto antenna was originally meant to be mounted on the rear of the car. This document provides you additional info about mounting the antenna, the graphs will probably be more clear to you than my words;): http://www.hirschmann-car.com/fileadmin ... a_2050.pdf
3771489
Post by 3771489 »
Automatic Aerial for e12 and e21 front:
This one is Bosch Autojet Standard (semi-automatic),Autojet Deluxe is full-automatic.
priest 008
3771489, what do you mean by Auto Aerial for the front? hedijan just said that auto aerials go on the back, is there a photo anywhere of an E21 with an Auto aerial on the front? :O
3771489
Post by 3771489 »
Meant just as i wrote. Installation manual:
heidjan
Post by heidjan »
Wow, didn't know auto antennas for front fender mounting also existed. Are these available on regular basis?
Never seen one of those... indeed, where to buy?
Post by 3771489 »
Jeroen wrote:Never seen one of those... indeed, where to buy?
Quite rare these days... Found and bought my from Canada.
