I have a 1980 323 with power mirrors and they are not working at all, and I see that there are 2 wirers that are cut running through the door jamb. I would assume that these are my weirs how ever you know what happens when you ASSume. I want to know if any one has a wiring diagram to post up or knows the colors of the wirers off hand.
need to fix Power Mirror wirers 1980 323 euro
peebuck
- Newbee
- My E21(s): 1980 323 euro with Alpina upgrades
To whom it may concern,
Re: need to fix Power Mirror wirers 1980 323 euro
From the factory there's no other wiring to the door so if you fix broken wires and check fuses first you may be well underway.
- polov8
I had a similar issue when I got my car, but after repairing the wiring, the mirrors still didn't work. Turned out the switch had burned a couple of tracks out on its connector.
Andy
