low rev bhp for the s14 b20 engine (320is)
rui freitas
Post by rui freitas »
hi!!! I´m new here and of course another Portuguese :wink: if you whant some extra bhp you can have it almost for free its not much but it noticeble at least at low revs ... the spark cables ,even new ,loose some capabilety to isolate electrical sparks after the engine is at running at temperature(hot) and because they are in contact whith each other confined to a "box". so to get that extra bhp at low revs all you have to do is keep the isolated from one to another... and trust me it realy makes a difference.I´ve put them each one confined to a pvc ramp and even at idle its more stable . cables are new about 3000km and have done about 1000km ago ...hope it helps in someone in some way... best regards to you all!!!
There are several aftermarket sets of ignition wires that are designed to go without the wiring loom (the box). But I can't imagine the problem will occur with a new set. But new sets wear faster in the original loom.
Pedro///Menezes
Post by Pedro///Menezes »
Another portuguese. Welcome!!
i've just bought a used but very good wiring loom from a M3, but i saw that it makes some nasty twists inside the box... :?
[b]BMW 2002 '71; 1602 '75 CPAA; 735i E23 '81; 325ix E30 '89; 320is E30 '89; 316i E30 '90; 316i Edition E30 '90; 318is E36 '93; 520i E34 '93; Mini 1000 '74[/b]
[img]http://img147.imageshack.us/img147/4338/316igy2.jpg[/img]
france320isco
Re: low rev bhp for the s14 b20 engine (320is)
Post by france320isco »
rui freitas wrote:hi!!! I´m new here and of course another Portuguese :wink: if you whant some extra bhp you can have it almost for free its not much but it noticeble at least at low revs ... the spark cables ,even new ,loose some capabilety to isolate electrical sparks after the engine is at running at temperature(hot) and because they are in contact whith each other confined to a "box". so to get that extra bhp at low revs all you have to do is keep the isolated from one to another... and trust me it realy makes a difference.I´ve put them each one confined to a pvc ramp and even at idle its more stable . cables are new about 3000km and have done about 1000km ago ...hope it helps in someone in some way... best regards to you all!!!
More HP giving air between the ignition cables? well that would be enough for the Stoccolma Nobel i think :wink:
