Are there any alternative solutions for the brake master... ? Will an E30 one fit?
Brake Master Cylinder RHD... Alternatives?
Reck
Having trouble finding a reasonably priced master cylinder. Linwar want £220 plus the old one, and the dealership want a whopping £430!!!
Re: Brake Master Cylinder RHD... Alternatives?
We have this topic called E21 suppliers list - the bmwe21.net directory
Some good addresses in there, isn't Bigg Red able to supply an overhaul kit at a decent rate? The parts really cost peanuts so something must be possible.
BTW dealer charges 101 Euros here for an overhaul kit, so that will be under 100 GBP. Also found this website in Germany with some NOS. They sell the same kit for € 69 but I'd have second thoughts... it is a way old part so even when new, unused and original Até, it still is rubber that's almost antique.
http://www.bmw-oldtimerteile.de/index.p ... e21-detail
Reck
Thanks Jeroen!
See the FAQ section for some details on rebuild etc: http://www.bmwe21.net/forum/viewtopic.php?f=38&t=13418
- davidvincent
- My E21(s): 1982 320/6 Lapis Blau
Double check you exact part number (I think it's 34311102219) but BMW supply ATE brake masters, but you can get an ATE one here for £120:
http://www.mister-auto.co.uk/en/brake-m ... _g258.html
Or the TRW is a tenner less... free delivery... you may need to call them to ensure they send a RHD one though.
Reck
Thanks mate but I'm pretty sure the RHD ones are out of stock pretty much everywhere. Thankfully my master actually held up on a full drain and refill/bleed!
FYI all Linwar are selling reconditioned RHD masters for £190+VAT.
Looks like the overhaul kits are the same for LHD and RHD though!
- davidvincent
Well done on the temporary fix!... but if you do want a replacement I usually find by calling a couple of suppliers (like the one I mentioned) they can order a RHD in for you and have it in a few days.Reck wrote:Thanks mate but I'm pretty sure the RHD ones are out of stock pretty much everywhere. Thankfully my master actually held up on a full drain and refill/bleed!
Failing that, there's always >>>>> http://www.wallothnesch.com/hauptbremsz ... 06-01.html
Another decent option is Simon at C3 >>>>> enquiries@c3bmw.co.uk
Good luck with it.
the internals of the LHD and the RHD are the same. I know this because I ordered a RHD from mister auto and they sent me a LHD instead. not wanting to lose time I just took them both apart and swapped the LHD stuff straight into the RHD master and then bench bled it and it worked great.
I used a pressure bleeder to force the fluid through rather then pumping the pedal. I am sure that its probably been changed already at one point
- David Mc
- E21 starter
Get the old cylinder bored and lined with a stainless steel sleeve, then put a repair kit through it and never touch it again. This has worked for me for over 20 years with brake and clutch master and slave cylinders for cars, tractors and trucks (including my E21).
you could try these for s/s resleeving, http://www.pastparts.co.uk/
1976 e21 320i A4 Alpina #1755
Gazman
- Newbee
- My E21(s): 1981, Reseda green 323i, manual.
I had a stainless steel restoration/ conversion done to mine by Fritz bits, came back like brand new and does what it is supposed to do, think it was about £160 with the Vat and postage, simplest and best option really.
“The fundamental cause of the trouble is that in the modern world the stupid are cocksure while the intelligent are full of doubt.”
― Bertrand Russell
― Bertrand Russell
Reck
Thanks all... Plenty of options now!
