Which Glass ? (Windscreen)
Doey
My E21(s): 1983 316
Post by Doey »
May seem like a stupid question but is there a way of finding out which glass my car has ?
From what i can see it looks just standard clear but i know you can get bronze / green , I just want to make sure before ordering
Its an A reg 1983 316 (1.8 carb)
Thanks
Re: Which Glass ? (Windscreen)
Use a big sheet of white paper, half of it behind the windscreen, half of it sticking out the open door. Then you should be able to see a clear difference, or hardly any at all.
Doey
My E21(s): 1983 316
Post by Doey »
Jeroen wrote:Use a big sheet of white paper, half of it behind the windscreen, half of it sticking out the open door. Then you should be able to see a clear difference, or hardly any at all.
At first i thought you were joking but after thinking about it that makes perfect sense :thumbsup
Thanks
I do have my serious moments you know :wink:
e21Keith
My E21(s): '81 323i Manual
Post by e21Keith »
My Y reg 316 has bronze tint. If you take the last 7 digits of your chassis number to your local BMW dealer they can provide a build spec which should tell you all bout the factory glass
Charlton
My E21(s): 81 320a 6cylinder
Post by Charlton »
Where can you order a screen from as I can only find green tint and need a bronze now thanks in advance
Charlton
Post by Charlton »
Do you know here I could get new rubbers front and rear
Charlton
Post by Charlton »
Reck
Post by Reck »
W+N or the dealership? Glass you should be able to get from Fritz Bits. That's where I got my last bronze side window from.
