Sills not draining water out
Mucka
My E21(s): 320
Post by Mucka »
Hi
My e21 has been standing a week during some heavy rainfall and when I moved it loads of water came out of the sills both front and rear drain holes, what could cause the water to gather in the sills?
Any ideas would be good :)
Thanks
mr edd
Re: Sills not draining water out
Post by mr edd »
if your car has a sunroof the drainage pipes run down the A post into the cills.
e21 316 (1981) TRE702X.
Mucka
My E21(s): 320
Post by Mucka »
Thanks, can anything be done to repair the pipes or re route them?
jimbob
Post by jimbob »
Im poking mine out of the ends of the sills so it drains out of the wheel arch instead of the sill
there is already a hole in the sill end for it you just have to put a hole in the wing to match
E36 328i Daily driver
E36 328i Touring
LeeLee
My E21(s): E21 316 1981
Post by LeeLee »
I did this take speakers out drill some holes toward the front of the car in the speaker holes and bend them to route them out and drill hole in plastic inner arche cover and screw some cable clips in to hold it out the way of the front wheels
arshad76
Post by arshad76 »
LeeLee wrote:I did this take speakers out drill some holes toward the front of the car in the speaker holes and bend them to route them out and drill hole in plastic inner arche cover and screw some cable clips in to hold it out the way of the front wheels
I'd second this. Also to make sure blow some compressed air through the sunroof holes. If water blows back you've got a blockage for sure. I had water collecting after having a new sill fitted and the welder literally welding/melting shut the drain holes.
Dr Jim, cut the offending part of and extended the originals with some more tubing held on with a jubilee clip and some strong sealant.
UK Moderator
Mucka
My E21(s): 320
Post by Mucka »
Great advise thanks,
I don't think I have speakers in the front of mine, I don't have a radio slot anywhere on the dash, I'll remove the carpet and have a look.
Is this the standard location?
This is a car with a/c. Cars without have the radio in horizontal position.
Mucka
My E21(s): 320
Post by Mucka »
I didn't spot that :) I only looked at the speaker locations
e-einundzwanzig
My E21(s): '82 318i manual
Post by e-einundzwanzig »
Yes, this is the standard location
