Hi everyone,
I have a BMW E21 323i and I want to put a M20B25 from a BMW E30 325i.
I would like to know if someone in this forum already did this swap or if you know exactly what things I have to change in order to do this. I would use everything stock except the ECUthat I already bought a Megasquirt.
I am using a 5th gear dogleg gearbox.
Thanks.
BMW E21 323i M20B23 swap to M20B25
- arshad76
Re: BMW E21 323i M20B23 swap to M20B25
Hi Simon,
This conversion has been done many, many times. Did you try searching for previous topics? You should find everything that you need. I'd say it's a worthwhile conversion and I had it done to my E21 too. Good luck
UK Moderator
"Megasquirt" i like that !
I am trying to get the engine maps in order to start testing, do you know were I can get them?BertjeConti wrote:"Megasquirt" i like that !
I will be posting new information here, this might take some weeks.
I have maps for my M20B20. Engine runs perfect with these maps.
I presume they will do for a start for your engine.
What ignition setup are you planning ?
I am not decided yet. What do you recommend?BertjeConti wrote:I have maps for my M20B20. Engine runs perfect with these maps.
Ok, it would be great if you could send me those maps.
Thanks
The easiest ignition setup is a wasted spark setup. You'll need a 6 cilinder coil pack for that. You won't need a cam shaft sensor for this setup and even then choose for a semi sequential injection setup.
I did it this way and i like it because it isn't complicated and much better than the standard motronic.
I''l pm you my ignition and ve tables.
