Radiator upgrade for an M10
Lion_UK
My E21(s): '82 316 Auto
Post by Lion_UK »
I want to improve the cooling on my 316, any recommendations on upgraded radiators?
Any other tips and tricks are surely appreciated!
Reck
Re: Radiator upgrade for an M10
Post by Reck »
Unless you're racing/tracking or running some hot engine upgrades, the stock radiator is good enough. If you're overheating at the moment, the cause is probably not the rad (unless it's blocked!).
Failing that, there are a few easy 'upgrades' out there; universal electric intake fans, low temp thermostats, waterless coolant, alloy radiators etc.
stefankj
Post by stefankj »
I'm using this radiator for my M30 turbo swap, but might be a overkill for a 1,6L :mrgreen:
http://www.ebay.com/itm/3-ROW-ALUMINUM- ... 18&vxp=mtr
1982 315
Reck wrote:Unless you're racing/tracking or running some hot engine upgrades, the stock radiator is good enough. If you're overheating at the moment, the cause is probably not the rad (unless it's blocked!).
Fully agree. Don't work around problems, find the cause.
PeteK
My E21(s): 1979 323i Euro
Post by PeteK »
There's definitely something wrong if you need to upgrade your radiator. I've got a 2 litre M10 pushing out 151 hp at the wheels and it has the standard radiator.
petroscf
My E21(s): '77 EU 316 manual
Post by petroscf »
Reviving this thread, in order not to open a new one, as I have a problem of exactly this sort
Have replaced my thermostat by a new one (I think it is the low temp as well), have fitted an electric fan, and have had my radiator fully cleaned...When I drive uphill, the temp indicator starts climbing over the middle indication. And in spirited uphill driving (aka chasing the car to translate from greek slang ) temperature reaches high indications, near the next indication (3/4) or even more close to the red.
Maybe it is just time for a new rad? (or at least just the "cellulosic" part) if available
/oo=00=oo\
E21 Forever
Read the FAQ section. I believe the M10 cooling system has enough capacity so perhaps your sensor is bad or the radiator clogged. Don't start inventing workarounds for problems, do somd measurements with an infrared/laser thermometer for example.
petroscf
Post by petroscf »
Noticed that my overheating problem is not general: Driving a couple of times, on fairly hot days (yes, summer has already started in our neighbourhood) temp both times rose only during uphill driving with heavy foot on the gas. At the same time, I noticed oil temperature reaching 92-95 degrees, while on straight (or downhill), water kept very normal figures, and oil was between 75-85
Still wonder what can be causing this - should I possibly be patient for some more kms, due to the engine still needing "break - in" period in order for metal tolerances to increase?
/oo=00=oo\
E21 Forever
Radiator clogged, thermostat not opening fully, air in the system, old water pump are common issues. It could also be the radiator cap is opening too soon so the system cannot build up pressure and therefore overheats. First things to rule out.
petroscf
Post by petroscf »
Shouldn't it overheat all the time?
/oo=00=oo\
E21 Forever
Why? It produces more heat under load.
petroscf
Post by petroscf »
:thumbsup
/oo=00=oo\
E21 Forever
