Air filter options - M20 / Weber
- davidvincent
- My E21(s): 1982 320/6 Lapis Blau
Hi all
I'm looking at replacing the stock air filter assembly on the 320/6, I have a few questions however...
If I install something like this:
http://www.webcon.co.uk/shopexd.asp?id=15106
What would then happen to the head breather hose, and the warm air intake?
I have the Weber DGAS 38 carb.
I have seen small pod like filters from k&n which could handle the breather hose, any experience with this?
I have no idea if the carb and the new filter assembly will need the original warm air feed.... again any advise would be appreciated.
Thanks all
Dave
Thanks all
Dave
Reck
Re: Air filter options - M20 / Weber
The head breather hose can either be extended down towards the bottom of the car to vent to atmosphere (so it doesn't foul your bay with oil vapours), or you can install a catch can... The warm air feed pipe can be removed completely - I think it's only warmed by the exhaust manifold/heatshield anyway? I've never missed the warm air feed. TBH you want cold air going into the Weber anyway!
- davidvincent
Reck wrote:The head breather hose can either be extended down towards the bottom of the car to vent to atmosphere (so it doesn't foul your bay with oil vapours), or you can install a catch can... The warm air feed pipe can be removed completely - I think it's only warmed by the exhaust manifold/heatshield anyway? I've never missed the warm air feed. TBH you want cold air going into the Weber anyway!
Thanks very much mate.. So do you have a similar setup?
Dave
Reck
M10 with a Weber, so similar.
I'm making an assumption that the warm air feed on the M20 is exactly the same as the M10 though.
- davidvincent
Ah okay cool.Reck wrote:M10 with a Weber, so similar.I'm making an assumption that the warm air feed on the M20 is exactly the same as the M10 though.
So you've also done away with the original airbox? What did you use to replace it?
Thanks
Dave
Reck
Yep, I hated that pancake! I used an aftermarket low profile filter (model 401 - that's for a 32/34 DMTL, but perhaps email them re the 38?);
http://ramair-filters.co.uk/rs-carb-fil ... plate.html
Has to be low profile because the bonnet won't close otherwise!
Here's a picture;
Here's a picture;
- davidvincent
Ah yes that looks spot on, I'll definitely give them a shout!
Thanks for the info
Thanks for the info
- davidvincent
I just remembered that there's also one vacuum hose that runs from the weber up to the original airfilter - any idea what happens to that? I still have the red rubber cap that was on the original solex, do I just cap it off?
Thanks
Dave
Thanks
Dave
Reck
I'm not sure on that one to be honest mate. Maybe contact Weber directly for a diagram, or someone else can advise.
