I have an 1982 316 Auto with the Pierburg 2B4 carb - my mechanic was investigating a rough starting issue and noted that it had an air leak which was causing it to run rich.
Where can I get a gasket/service kit for one of these and fast?
All help is appreciated!
Pierburg 2B4
Re: Pierburg 2B4
Bin it and buy a weber would be my advice. Not sure you can get service parts for the pierburg anyway, but the weber is a massive improvement!
http://www.webcon.co.uk/shopexd.asp?id=971
1982 Saphirblau Baur 325i
Cars all gone!
Cars all gone!
Re: Pierburg 2B4
Compared to an old carb and fresh carb will give a huge improvement just like fresh shocks always amaze you. But that doesn't make the 2B4 impossible. Don't Ruddies Berlin have a kit for those?
Lion_UK
- E21 starter
- My E21(s): '82 316 Auto
Re: Pierburg 2B4
Thanks for the link. Am I right in guessing that I'll loose the auto choke with a replacement kit?
Re: Pierburg 2B4
I'm not sure, when I webered my old 316 I did. The auto choke is a bit bobbins anyway, anyone capable of driving an e21 should be able to pull a little knob in the dash and push it back in once warmed up a bit!
Just remember to connect all the wires up, it won't work otherwise as I found out!
Cars all gone!
Cars all gone!
nuke laars
- My E21(s): 1983 Baltic Blau 316
Re: Pierburg 2B4
I found these guys to be helpful and knowledgeable in my days of owning a T3 Transporter with a Pierburg.
http://www.gowerlee.dircon.co.uk/spares.html
1983 Arctic Blau 316
1989 Sterling Silber 318i
Lion_UK
- E21 starter
Re: Pierburg 2B4
Ended up ordering a service kit from Eastern Europe which worked a treat. My mechanic gave it a full service and now shes driving much better.
On a side note I also found Webcon in Ashford (after I placed by order) who had parts and knowledge - will use them the next time I need anything.
