Hey everyone,
I have a US Spec 1983 320i that has been running in perfect condition. No dips in power, good clutch, no scary vibrations. I changed my oil for the winter season on Thursday and the car has still been running fine since. However last night I went to go replace a faulty turn signal bulb (the bulb was stuck on super bright) and when I went to start her back up the car wouldn't start. I moved the car to the curb before working on the bulb so something happened during the time i replaced the bulb. I tried to jumpstart the battery and that didn't work. The starter motor is clicking in rhythm and trying to start but nothing will catch. I recently replaced my timing belt and it still works fine. Is there anything I am missing? I removed and replaced a fuse in the fusebox, but that was only for the turn signal.
Is there any advice anyone can offer? Thanks!
Changed the turn signal light bulb, and now car won't start
Re: Changed the turn signal light bulb, and now car won't st
Check all your fuses and give all a turn in their brackets, they tend to corrode and this may cause your ignition or fuel pump to fail.
