e21 315 => 335i turbo
stefankj
Post by stefankj »
Hi guys
I've been a member for a while but never made a thread about my car so here it goes. The car is a 1982 315 with 138k km on the clock.
I can tell you the story why I bought a e21. When I was younger I walked past a e21 everyday on my way to school, it was a clean blue 323i and I loved that car and thought to myself someday I will buy myself a e21, but since I live in Iceland there are very few e21's left on the streets so when I saw my e21 for sale I had to buy it even though it was only a 315. And then this whole project started, first I bought the m30b35 for the swap and was just going to swap it in, then I found a e23 745i turbo kit for sale and bought that to put in as well, but then desided to sell that kit and go for something bigger... so here I am, in too deep and trying to piece this car together, here is where I am with this today.
1982 315
Re: e21 315 => 335i turbo
Serious project!!
polov8
Post by polov8 »
I'm liking the diff plate double mount thingy, great project!
Andy
TopCat
My E21(s): 1980 Alpina B6 2.8
Post by TopCat »
love it!
Regards
Topcat
Isle of Man Inverness
1980 BMW E21 Alpina B6 2.8
1991 BMW E30 Hartge H26
pandemonium001
My E21(s): E12 535i T (ish)
Post by pandemonium001 »
warmest of Welcome's
Thats one sturdy diff mount!!
what turbo is that HX52 with 11cm turbine housing?
Interesting idea with the remote manifold for the wastegate/fuel reg & dump valve. why not just drill and tap the alloy manifold?
remember pictures pictures and more pictures.
:thumbsup
E21noob
My E21(s): SOLD
Post by E21noob »
Love the idea of the diff mount! Any more pics and details on that?
stefankj
Post by stefankj »
some progress, downpipe and some bootwork, The turbo I'm using is borg warner s360 T4
1982 315
stefankj
Post by stefankj »
Time for some update.
Hoses and oil-cooler
Air and breather filters
Rear disc brake conversion using 323i discs and audi calipers( girling 36) with integrated handbrake, the standard cables can be used with some modification.
Main battery switch, three switches for fuel pumps, wideband and a small tablet wich connects wia bluetooth to megasquirt.
Need to finish the exhaust system now...
1982 315
croma_man
My E21(s): '83 EU 327i
Post by croma_man »
china intercooler? I have a similar thick one on my turbo passat project, massive problems with the intake temperature as it doesn't cool the air (too thick or too low flow)...they told me never to save money on intercoolers, and its true.
stefankj
Post by stefankj »
croma_man wrote:china intercooler? I have a similar thick one on my turbo passat project, massive problems with the intake temperature as it doesn't cool the air (too thick or too low flow)...they told me never to save money on intercoolers, and its true.
This cooler is not cheap and not from china, this one is a upgrade for a 335i or 135i with twin turbo n54( two small turbos generate/transfer more heat than a single large), I have put this same cooler in a modded e90 335i and we saw a very nice intake temperature drop from the stock cooler so I'm not even a little worried about this one for my setup.
1982 315
stefankj
Post by stefankj »
Some info about motor modifications
Oil squirt-nozzles for piston cooling installed(same as in 745i and alpina b10 biturbo) and the block honed and decked 0,3mm
Alpina B7 turbo pistons installed with 745i rings gapped for extreme cylinder pressure
ARP head studs and MLS gasket
New valve springs (stock on right new on left)
Custom grind special turbo camshaft from Paul Burke
Cam specs
Head also has rocker arm locks, and the throttle body i'm using is 90mm(stock is 68mm), injectors are 695cc/min(66lb)
1982 315
