e21 323i/320 Clutch
e21Keith
My E21(s): '81 323i Manual
e21 323i/320 Clutch
Post by e21Keith »
Hi.
Does anyone know what the difference is between a 320/6 and a 323i clutch is?
The clutch plate is compatible but the cover plate has a different part number, does anyone know what the difference is?
Many thanks
Re: e21 323i/320 Clutch
Pressure plate stronger perhaps? Dunno but it is slightly different indeed.
Post by 3771489 »
Jeroen wrote:Pressure plate stronger perhaps? Dunno but it is slightly different indeed.
Exactly.
:thumbsup quite a difference as well, didn't expect that!
always good to have a factory manual on hand but that was a bit too much on my mobile
e21Keith
Post by e21Keith »
Thank you,
If only I understood German!
I assume it means the cover plate has a higher pressure!
Yup, pressure force in Nm
