Fuel leak right under rear seats while engine is on!
pihlen
My E21(s): '81 318i, manual, swedish, silver
Post by pihlen »
Hello,
I realised today that it smelled gasoline while driving and I stopped at a parking and realised that it was literally running fuel (not only dripping) from underneath the car. When I turned the engine off it stopped running underneath the car. It was running pretty much right under the rear seat and it seemed to be a little to the cars right side (it was hard to see exactly).
Since its only while the engine is on i guess its something with lines from the fuel pump somewhere where pressure from the pump is needed to reach to? So not like a hole in the tank or something like that...
Any ideas anyone? Appreciate any help!
Always thankful for y'alls knowledge and help! (So far I guess I´ll get more help then being able to help out my self..so far) :)
Stefan from Gothenburg, Sweden.
https://www.instagram.com/p/BDLw16AM6dC ... schteeffoh
Re: Fuel leak right under rear seats while engine is on!
Tank all filled up? The common problem is a leaking hose between the two tanks or the hoses on top of the tank, so it usually appears with a filled up tank.
Since your problem seems to be on or off with the engine, I think tour fuel line is corroded, or it is the hose between pump and line.
Put it on a ramp and you will see.
pic
Post by pic »
It's the fuel line that goes from the fuel filter to the engine. Change the rubber hose, diameter is 8mm. Take it out the back seat, and there is a door. Take it off, tie off the rubber hose from the metal tube, tie off from the fuel filter, and change the rubber hose. Not a big job.
See the FAQ section for detailed info: viewtopic.php?f=38&t=18255
Thats a possibility, but I have seen a fair amount of cars with rotten fuel lines...
pihlen
Post by pihlen »
hi guys, i took the rear seat out and unscrewed the little hatch and yes - when i started the fuel pump it litterally started a fountain spraying the rear side of the front passengerseat! pretty dramatic w a petrol fountain in the car. i have now changed the fuel line from the filter and it works perfect. thank u all again!!
:thumbsup
:thumbsup
