Smelly fuel tank breathers
TopCat
My E21(s): 1980 Alpina B6 2.8
Post by TopCat »
I have noticed a slight petrolly smell in Herman's Boot
I am going to check the fuel tank breathers- somewhere I have read that these are accessed via a trapdoor under the rear seat. Is this correct? If not how do you check for this diagnosis please?
Regards
Topcat
Isle of Man Inverness
1980 BMW E21 Alpina B6 2.8
1991 BMW E30 Hartge H26
mr edd
Re: Smelly fuel tank breathers
Post by mr edd »
i don,t think you will be able to get at the breather pipe via the hatch .The breather pipe connects to the top of both tanks with a three way jointer then go,s towards the drivers side cill into a steel tube behind the drivers side rear interior panel which then go,s over the drivers side rear inner wheel arch into the boot and connects to the neck of the fuel filler.....drop the drivers side fueltank to get at the hidden end of the breather hose ...i can email you a pic of under the car with tanks removed so you can see the route of the breather hose if it helps...edd
e21 316 (1981) TRE702X.
Heinrich
My E21(s): '81 323i TC-1 Baur 5-speed
Post by Heinrich »
Hi sir,
Could you email med a picture allso please?
I have the same problem...
TopCat
Post by TopCat »
mr edd wrote:i don,t think you will be able to get at the breather pipe via the hatch .The breather pipe connects to the top of both tanks with a three way jointer then go,s towards the drivers side cill into a steel tube behind the drivers side rear interior panel which then go,s over the drivers side rear inner wheel arch into the boot and connects to the neck of the fuel filler.....drop the drivers side fueltank to get at the hidden end of the breather hose ...i can email you a pic of under the car with tanks removed so you can see the route of the breather hose if it helps...edd
Driver's side- meaning rhd driver?
Regards
Topcat
yes filler cap side :)
these are rubber pipes coated with fabric, they are brittle and horrible on every e21 i have seen.
You have to drop the tanks to change them. its not a difficult job to do really but itll take a day or a good weekend. the less fuel you have in the tank the better.
See the FAQ as well mate
