Engine Idling
phealy
My E21(s): 1982 European 323i Auto
Engine Idling
Post by phealy »
Hi Guys, I've recently acquired a 1982 (Reg UK 1 Aug 1982) 323i Auto with an original factory supplied engine. I don't know a lot about engines, so wondered if you could give me any advice before I take it to a garage.
When I cold start the car is starts without problem and idles nicely 8-900 RPM.
Then once it's been running for a 4 or 5 mins when the engine temp get nearly halfway, where it usually sits, the car idles lower, maybe 6-700 RPM.
And once it's up to normal temp it it idles around 500 RPM. It seem quite low and feels like it's going to stall. It hasn't yet, but that's mainly because I don't leave it idling too long.
Any thoughts on why this might be, or what might be done to stop the engine revs dropping once the engine heats up?
Many thanks,
Paul
pic
Re: Engine Idling
Post by pic »
First to check vacuum leaks. If all okay, try to adjust the idle speed with the screw on the throttle body when warm.
phealy
Re: Engine Idling
Post by phealy »
pic wrote:First to check vacuum leaks. If all okay, try to adjust the idle speed with the screw on the throttle body when warm.
Thanks Pic. Found a leak on one of the hoses. Fixed that and it's perfect now. Brilliant thanks.
Re: Engine Idling
Wow that was easy! :thumbsup
