Diffs
healeyneil
Diffs
Post by healeyneil »
Hi. I cant find what diff ratio mine has. It was a 320 auto. The specs pages only seem to have spec for manuals. I think I read somewhere its 4.1 to 1. Anyway, Its now revving too high for comfort ( but it accelerates very nicely )
Is it true that the crownwheel and pinion from 3series up to the E36 will fit ?
Alternatively, anyone fancy a swap ? Im not looking for an LSD, open is fine.
Thanks, Neil
Re: Diffs
E21's came with the same diff ratio no matter manual or auto.
healeyneil
Re: Diffs
Ah, OK thanks Jeroen.One less job to do then :)
mr edd
Re: Diffs
Post by mr edd »
320 3.64 to one.
323 3.45
316(1800cc)3.9...
316/315 (1600cc) 4.1
e21 diff ratios (from memory)
e21 316 (1981) TRE702X.
Re: Diffs
As per the specs pages or the topics on diff ratios you'll find using the search functionality :wink:
