PAS Upgrade
- joe14
- My E21(s): 1983 black 316
PAS Upgrade
I'm looking into a power steering upgrade to utilise the power steering pump on my new engine.
I've seen people use the E46 'purple tag' rack (3 turns lock to lock).
1) Am I right in saying that a LHD rack will be required for a RHD E21 due to it needing to be turned around?
2) Besides mounting brackets, what else is required? tracks rods modified? steering linkage?
Thanks.
Joe
Thanks.
Joe
Re: PAS Upgrade
NAS just listed some E21 PAS gear in the for sale section
I gave up on PAS as couldn't work out how the pump tensioner/bracket went together!
1982 Saphirblau Baur 325i
Cars all gone!
Cars all gone!
Re: PAS Upgrade
I would usea stock pas rack and a 1.5 steering quickener.
Theres probably a bit less fabrication then swapping a LHD rack and trying to make track rod ends work maybe?
BTW Joe, ya 6cyl subframe will be ready for ya soon.
Re: PAS Upgrade
Re: PAS Upgrade
No. You can be the first if you wanted lol.
Re: PAS Upgrade
I have a spare LHD column you can have a go on?
Re: PAS Upgrade
Neh I'm ok with my steering rack as it is. It's not E30 M3 short but ok for street use and not vague or too long.
- joe14
Re: PAS Upgrade
Oh this will be one to think about then. Looks like they're used in a lot of motorsport applications.
I think the trick will be finding somewhere to mount it and ensuring its straight and doesn't foul the exhaust manifold.
Re: PAS Upgrade
Can't you just use the E21 PAS rack on your conversion then?
- joe14
Re: PAS Upgrade
Yeah I could but I'd like something quicker tbh.
I'd fancy a non PAS quick rack except for the added weight but making it power assisted gives the best of both worlds.
