323i Rear Caliper Banjo Fitting Brake Hose
e21Keith
My E21(s): '81 323i Manual
Post by e21Keith »
OK, rebuilt my rear calipers myself and pretty happy with the job.
The car had the original Banjo rear hoses, I bought a set of replacements from Germany but the Banjo is not thick enough to enable me to fully tighten the banjo bolt, hence they are going to leak.
So what's the option. genuine hoses from BMW are £69 each +vat and I'd rather not spend that much.
Do I shorten the Banjo bolt by cutting, can I get the hoses cheaper elsewhere is there another option with regular hoses?
E21noob
My E21(s): SOLD
Re: 323i Rear Caliper Banjo Fitting Brake Hose
Post by E21noob »
I think I got some on ebay. Just asked if they could provide only those. I'll see if I can find the seller. Havent fitted them yet so cant say if you would meet the same problem. I'll check cost too.
E21noob
My E21(s): SOLD
Post by E21noob »
2 caliper hoses supplied with banjos bolts and copper washers.
To replace the two outer lines on each side to replace BMW part number 34321120013
Part number 7 in this image:
http://www.etk.cc/bmw/EN/search/fg/34_0097.jpg
£44.99 plus shipping
Daghosesupplies
Bosch, 8 Euros each, from Germany. Link is to a Dutch language site but usually you get a pop up to choose language
https://www.auto-onderdelen24.nl/bosch/1188964
e21Keith
Post by e21Keith »
Thanks for all the replies. The pair I bought on ebay sat in my garage for a year and it was only yesterday I discovered they were incorrect. Research on the W+N site shows what looks like the same hoses that I bought with new banjo bolts and washers, so my understanding is I just need to order a couple of new banjo bolts that are shorter.
