M20b20 engine stand
bealo
My E21(s): 83 316 1.8
82 320/6
M20b20 engine stand
Post by bealo »
Hi guys
Does anyone know what size bolts to use to mount a m20b20 to an engine stand?
I believe it’s m12 x 1.75 but not sure on length
Am I right in thinking it mounts to the stand using the gearbox bolt holes?
Can I mount it without taking off the flywheel and clutch?
Cheers Iain
Re: M20b20 engine stand
Indeed, you use the gearbox mounting holes. Here is a hint about the bolts:
http://bmwfans.info/parts-catalog/E21/E ... ing_parts/
There are in the internet some examples of engines mounted to the side.
If I look at my old pics of mu M10 than there is not too much place actually to leave the clutch and flywheel on:
No, you do want to remove clutch and flywheel8
bealo
82 320/6
Post by bealo »
Ok thank you, any idea on length off the bolts required?
Have you had a look at the link? And it depends as well from the engine stand you have.
How about the lenght of the stand arm, and then a good inch.
bealo
82 320/6
Post by bealo »
Thanks guys most helpful 👍🏻
