Car is running at around 1500-1800 revs when warm
Not to sure why . Ive had the fuel regulator and warm up regulator reconditioned and engine rebuild. what is the correct set up
ie co ,
323i set up
Re: 323i set up
How many revs does it do at cold start and during warmup, even more? In that case it would be safe to adjust the idle screw on the throttle body, the big brass screw on top. I get the best results at around 950 rpm and a CO of approx. 1.6-2.0%
cobbler2u
- My E21(s): 323i baur
323i special
328 sport
Re: 323i set up
found problem to be the air aux valve
