How does it work:
No changes in the engine bay, the original precise manual steering rack (or even quick rack?!) can remein fitted including your fresh tie rod ends
What changes, is hidden under the dash. The original steering column is replaced by one with an electric motor (you get to keep the original if you ever want to change back). These power assisted steering kits are speed dependent using a pulse sender connected to the speedo (between cable and speedo), they're not using GPS data as seen in cheaper systems which may cause issues when there is no GPS signal like in tunnels. Manual adjustment of assistance is also possible and is being used for rally and race applications.
Fitting takes 4-5 hours max, a lot faster than fitting a conventional hydraulic system. Another advantage is that the setup only absorbs power when turned in a lot (usually only during parking and city use) while conventional systems use power continually. Electrical systems can and will not leak and do not need any maintenance.
Below a few pics of kits applied in E21 and E30 models and here are the installation manuals as .pdf (only Dutch version available to me atm): E21 ; E30
Pricing (ex 21% VAT):
Full electrical kit for E21 or E30 € 1.250,-
Installation by EZ Powersteering € 500,- (in the Netherlands)
If there's enough interest it may be worth while to set up a Group Buy.
Pricey? Don't think so, used PAS kits fetch quite some money these days and will at some point require an overhaul of rack and pump.
Manufacturer:
EZ Powersteering
Energieweg 21A
4143 HK Leerdam
The Netherlands
Phone. +31-345-633551
Contact: Mr Ruud Jong
www.ezpowersteering.nl power steering & classic steering parts
Fitted to E21:
original
neuw
Fitted to E30:
