H1 double interior headlights cloudy
lolomovil
My E21(s): Euro BMW 323i E21
Post by lolomovil »
Hi, I bought some NOS Hella headlights and I noticed that the interiors have a cloudy appearance (they have a kind of white substance inside). The funny thing is that the exteriors headlights are perfectly clear. I have also seen many photos (including press photos) in which the interior headlights seem to look like this. Is this normal or is it a defect? Can they be cleaned?
Regards.
e21Keith
My E21(s): '81 323i Manual
Re: H1 double interior headlights cloudy
Post by e21Keith »
Yes they can be cleaned. I have had good results using tablets used to clean dentures. The brand I used was Steradent. Left them to do their work overnight and the results were good. Of course you need to have the headlamp removed and sitting face down on the glass when you do this.
I used this method on my e21 headlights.
Yep, known method indeed!
e21Keith wrote: Thu Feb 27, 2020 6:38 pm Yes they can be cleaned. I have had good results using tablets used to clean dentures. The brand I used was Steradent. Left them to do their work overnight and the results were good. Of course you need to have the headlamp removed and sitting face down on the glass when you do this.
Yes, did that also, but mind you, flush them with demineralized water, to prevent calciumspots from appearing.
lolomovil
Post by lolomovil »
Thank you very much for your answers. I will try to clean them that way. So everything, one thing catches my attention, all the headlights I've seen with that defect are interior ones.
