Can anyone tell me what the alignment data is for my 315 e21.
Redid some of the front end and needs an alignment.
thx,
Peter
Alignment Data
Re: Alignment Data
There's not much you can adjust. Rear does best on neutral or very slight toe OUT (0.5-1.0 degrees), can be tough to adjust, if reasonable, better leave it. Front is much more important and minimal toe IN appears to work best, I usually set it at around 0°10'.
PeterCS
- My E21(s): 82 BMW Baur
Re: Alignment Data
thank you Jeroen and for all your efforts with this site. PeterCS
Peter Churchill-Smith
