Hi all,
What thickness material are people using to repair chassis leg?
Chassis leg
- My E21(s): 83 316 1.8
82 320/6 - Location: Essex
Re: Chassis leg
The rail that that the subframe mounts to in the engine bay
Re: Chassis leg
Ah oke. That is 1,5 mm, but 2 will do fine. 1mm is not recommendable. But is it a patch or a larger piece? They are still available at bmw, I thought...
Re: Chassis leg
A patch about 100mm wide. I’ve some 1.2mm I was going to use, just wondering if that will be ok?
