Hi all,
Wanted to do change the gearbox oil on my 316 1.6 4 speed gearbox. The manual calls for 80W oil - am I correct in assuming LIQUI MOLY GL4 80W mineral oil would do the job ok? Alternatively does anyone have any other recommendations?
Thanks
e21 Gearbox Oil
guerciotti
- E21 starter
- My E21(s): 1981 European 316 1.6
Re: e21 Gearbox Oil
Yup, or Castrol Transmax in the same spec for example. Hint: before removing the drain plug, remove the fill plug. Drains easier and prevents running into issues if the fill plug fails to come out properly. Never encountered that problem myself but I've heard some stories...
guerciotti
- E21 starter
Re: e21 Gearbox Oil
Thank you both.
